Ir para o conteúdo principal
Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement
O que você precisa
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: passo 1, imagem 1 %32 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: passo 1, imagem 2 %32 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: passo 1, imagem 3 %32
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Screws to Base Plate: passo 2, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: passo 3, imagem 1 %32 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: passo 3, imagem 2 %32 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: passo 3, imagem 3 %32
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 376
