Ir para o conteúdo principal
Polycom SoundStation Internal Keyboard Replacement
O que você precisa
  1. Polycom SoundStation Internal Keyboard Replacement, Back Housing: passo 1, imagem 1 %32
    • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
    • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
  2. Polycom SoundStation Internal Keyboard Replacement: passo 2, imagem 1 %32 Polycom SoundStation Internal Keyboard Replacement: passo 2, imagem 2 %32
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
  3. Polycom SoundStation Internal Keyboard Replacement, Internal Keyboard: passo 3, imagem 1 %32 Polycom SoundStation Internal Keyboard Replacement, Internal Keyboard: passo 3, imagem 2 %32
    • Gently lift the internal keyboard off of the motherboard.
Conclusão
Cali Nowak Credit
Membro desde: 09/02/14
431 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 1,574
