Ir para o conteúdo principal
Polycom SoundStation Back Housing Replacement
O que você precisa
  1. Polycom SoundStation Back Housing Replacement, Back Housing: passo 1, imagem 1 %32
    • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
    • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
  2. Polycom SoundStation Back Housing Replacement: passo 2, imagem 1 %32 Polycom SoundStation Back Housing Replacement: passo 2, imagem 2 %32
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
Conclusão
Cali Nowak Credit
Membro desde: 09/02/14
431 Reputação
Autoria de 4 guias
Equipe
Um comentário
thanks for this - the 7mm were under footpads so I couldn’t see them. cover now off, keyboard dried of coffee and working fine again!!
J M - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 1,118
