Ir para o conteúdo principal
Polk MagniFi Soundbar Bluetooth Cable Replacement
O que você precisa
  1. Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: passo 1, imagem 1 %32 Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: passo 1, imagem 2 %32 Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: passo 1, imagem 3 %32
    • To reveal the control button, first, carefully remove the front cover of the Sound Bar.
    • Use the plastic iFixit opening tool to lift up the front surface. Insert the tool between the cover and the body to open it.
    • After the cover is fully removed, it will be able to see the interior speaker.
    • Carefully unscrew all 16 screws to release the panel.
    • There are total 16 screws that secures the panel onto the cover. Each screw is approximately 1.50 centimeter.
  2. Polk MagniFi Soundbar Bluetooth Cable Replacement: passo 2, imagem 1 %32 Polk MagniFi Soundbar Bluetooth Cable Replacement: passo 2, imagem 2 %32 Polk MagniFi Soundbar Bluetooth Cable Replacement: passo 2, imagem 3 %32
    • To remove the cover behind the control buttons, insert the iFixit opening tool between the cover and the body
    • Push the opening tool along the edge of the cover to fully open it.
  3. Polk MagniFi Soundbar Bluetooth Cable Replacement: passo 3, imagem 1 %32
    • Underneath the cover, there is a black panel screwed onto the cover with two sets of wires plugged into it.
  4. Polk MagniFi Soundbar Bluetooth Cable Replacement: passo 4, imagem 1 %32 Polk MagniFi Soundbar Bluetooth Cable Replacement: passo 4, imagem 2 %32
    • Grasp the wire firmly close to the base and pull straight out. Repeat this for the other end of the wire.
    • This wire is easily broken. Handle with care.
Conclusão
[deleted]
Membro desde: 10/22/18
671 Reputação
Autoria de 4 guias
Um comentário
Can you pair it with Beats headphones.?
wayne rivers - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 2,434
