Ir para o conteúdo principal
Polaroid i533 LCD Screen Replacement
ashley
ashley e 14 outros colaboradores
Última atualização em 13 de out de 2020
Nenhuma estimativa
Moderado
Faltando detalhes
Introdução
Ir para o passo 1
When the screen on your camera breaks, it becomes almost completely unusable. This guide will show you how to replace the LCD screen on a Polaroid i533 camera.
O que você precisa
Ferramentas
  1. Polaroid i533 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Polaroid i533 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 Polaroid i533 LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • Remove the four 3mm screws from the left-hand side of the camera screen.
    • On the right-hand side of the camera screen, unscrew and remove the two 3mm screws.
    • On the bottom of the camera, unscrew and remove the three 3mm screws.
  2. Polaroid i533 LCD Screen Replacement: passo 2, imagem 1 %32
    • Slide the battery door open and slightly open the side of the case with a plastic opening tool.
  3. Polaroid i533 LCD Screen Replacement: passo 3, imagem 1 %32
    • Be careful not to pull the cover off completely, as it should remain attached to the motherboard.
    • Gently pull the cover away from the rest of the camera. Do not separate the pieces completely.
  4. Polaroid i533 LCD Screen Replacement: passo 4, imagem 1 %32 Polaroid i533 LCD Screen Replacement: passo 4, imagem 2 %32
    • Locate where the LCD screen ribbon is attached to the logic board.
    • Using the iFixit plastic opening tool, flip up the black tab that connects the LCD screen ribbon to the motherboard.
  5. Polaroid i533 LCD Screen Replacement: passo 5, imagem 1 %32
    • Gently pull the ribbon away from the motherboard. This will allow the cover to separate from the rest of the camera.
  6. Polaroid i533 LCD Screen Replacement: passo 6, imagem 1 %32
    • Locate the four screws in each corner of the LCD screen and carefully remove them. After they have been removed, ensure the screws stay separate from the 3mm case screws.
  7. Polaroid i533 LCD Screen Replacement: passo 7, imagem 1 %32
    • Remove the LCD screen from the remaining casing of the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
ashley
Membro desde: 06/24/10
19 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 3-4, Johann Summer 2010 Membro de Cal Poly, Team 3-4, Johann Summer 2010
CPSU-JOHANN-R10S3G4
4 Membros
Autoria de 9 guias
1Comentário do guia
great job and information
John Webb - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 3,819
