Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Replacing a broken or scratched lens on a Polaroid Sun 600 LMS.
  1. Move film door slide on the left side of camera forward. Pull film door open.
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Open the flash assembly by holding the sides of the top piece of the camera and pushing up gently until it snaps into place. If your camera is old or dirty, it may take more force to open the flash assembly.
    • Open the flash assembly by holding the sides of the top piece of the camera and pushing up gently until it snaps into place.
    • If your camera is old or dirty, it may take more force to open the flash assembly.
  3. Use a spudger on each side to separate the flash segment from the main body. Be careful not to do this too hard because you may pull out the connecting wires.
    • Use a spudger on each side to separate the flash segment from the main body.
    • Be careful not to do this too hard because you may pull out the connecting wires.
  4. Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame. Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame.
    • Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame.
  5. Place left hand on the gray section and right hand on the black section. Pull the sections apart.
    • Place left hand on the gray section and right hand on the black section.
    • Pull the sections apart.
  6. Carefully remove the damaged lens from the interior of the camera. Replace with a new lens.
    • Carefully remove the damaged lens from the interior of the camera.
    • Replace with a new lens.
Conclusão
Uma outra pessoa concluiu este guia.
Ian Hosek
Membro desde: 20-01-2010
345 Reputation
Autoria de 1 guia
Equipe
Cal Poly, Team 3-18, Maness Winter 2010 Membro de Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 Membros
4 Guias de autoria
Adicione um comentário
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 42
All Time: 8,260
