Ir para o conteúdo principal
Polaroid Sun 600 LMS Film Pack Replacement
  1. Polaroid Sun 600 LMS Film Pack Replacement, Film Pack: passo 1, imagem 1 %32
    • Locate film door and slide release latch.
    • The slide release is near the lower left corner towards the front of the camera.
  2. Polaroid Sun 600 LMS Film Pack Replacement: passo 2, imagem 1 %32
    • Slide side latch towards the front of camera.
    • The film door will pop open.
  3. Polaroid Sun 600 LMS Film Pack Replacement: passo 3, imagem 1 %32
    • Insert film pack.
    • Make sure the battery contacts on the film pack are facing down and in contact with the camera's contacts.
  4. Polaroid Sun 600 LMS Film Pack Replacement: passo 4, imagem 1 %32
    • Close film door by gently pushing it back into place.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Matthew Lessig
Membro desde: 01/20/10
63 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 3-18, Maness Winter 2010 Membro de Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
Membros da 4
Autoria de 4 guias
3 comentários
Where would you buy the sun 600 LMS battery film?
Albert Einstein - Responder
Where can I buy Sun 600 LMS instant battery film?
How do you fix the flash
Edward Flores - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 37
Duração total: 12,159
