Introdução
When replacing the battery, realize that there is an adhesive which binds the battery to the camera. Given the adhesive, force might be required to remove the battery. However, you should be able to remove it with your hands.
O que você precisa
Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
Screw head: Phillips, Screw length: 3mm
15 outras pessoas executaram este guia.
21 comentários
I would like to know where to buy it too.
Same question need to know where to purchase a new battery and is this a common issue for the snap touch
I also need a battery and it seems almost impossible to find one to buy. Please let me know if anybody has found a replacement battery that fits.
