Ir para o conteúdo principal
Polaroid S10 Speaker Replacement
O que você precisa
  1. Polaroid S10 Speaker Replacement, Removing the backcover: passo 1, imagem 1 %32 Polaroid S10 Speaker Replacement, Removing the backcover: passo 1, imagem 2 %32 Polaroid S10 Speaker Replacement, Removing the backcover: passo 1, imagem 3 %32
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Speaker Replacement, Speaker Assembly: passo 2, imagem 1 %32 Polaroid S10 Speaker Replacement, Speaker Assembly: passo 2, imagem 2 %32
    • Use a heavy-duty nylon spudger to remove the tape.
    • Unscrew the four 5 mm screws with the J000 screwdriver that connects the speakers.
  3. Polaroid S10 Speaker Replacement, Desoldering the Speakers: passo 3, imagem 1 %32 Polaroid S10 Speaker Replacement, Desoldering the Speakers: passo 3, imagem 2 %32
    • Carefully desolder the 4 connections of the speakers.
    • Do not touch the soldering iron to the motherboard or LCD screen.
Conclusão
James
Membro desde: 03/16/15
367 Reputação
Autoria de 3 guias
Equipe
Colorado Springs, Team 1-4, May Spring 2015 Membro de Colorado Springs, Team 1-4, May Spring 2015
UCCS-MAY-S15S1G4
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 361
