Introdução
Power is one of the biggest problems of the polaroid PMID 4312 tablet. This guide will show you how to replace the battery.
O que você precisa
Pry the seam between the screen and the case and slide it on all four sides with a large plastic opening tool until the plastic case comes off.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Wedge a plastic card beneath the battery unit and wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
