Ir para o conteúdo principal
Polaroid P902 LCD and Digitizer Replacement
O que você precisa
  1. Polaroid P902 LCD and Digitizer  Replacement, The Tools: passo 1, imagem 1 %32 Polaroid P902 LCD and Digitizer  Replacement, The Tools: passo 1, imagem 2 %32 Polaroid P902 LCD and Digitizer  Replacement, The Tools: passo 1, imagem 3 %32
    • The most important part of any repair is the tools used. Here's what I brought to this repair. Xool 58 in 1 Precision Screwdriver Set, DREMINOVA Heat soldering Mat Large Pad, and Xool 10pc EDS Anti-Static tweezers. I also always wear gloves when preforming repairs, my preferred gloves are Grease Monkey Disposable Nitrile Gloves.
  2. Polaroid P902 LCD and Digitizer  Replacement, The Back: passo 2, imagem 1 %32 Polaroid P902 LCD and Digitizer  Replacement, The Back: passo 2, imagem 2 %32 Polaroid P902 LCD and Digitizer  Replacement, The Back: passo 2, imagem 3 %32
    • First remove the two screws circled in the first picture with a PH00 bit.
    • After the screws have been removed take a plastic spudger and use it to lift the LCD from the backing
    • You will have to use some force don't be scared of it.
  3. Polaroid P902 LCD and Digitizer  Replacement, Ribbons: passo 3, imagem 1 %32 Polaroid P902 LCD and Digitizer  Replacement, Ribbons: passo 3, imagem 2 %32 Polaroid P902 LCD and Digitizer  Replacement, Ribbons: passo 3, imagem 3 %32
    • Next using the flat end of a plastic spudger release the clips holding the ribbon circled in the first picture.
  4. Polaroid P902 LCD and Digitizer  Replacement, The Screws: passo 4, imagem 1 %32 Polaroid P902 LCD and Digitizer  Replacement, The Screws: passo 4, imagem 2 %32
    • Next switching to a PH000bit remove the 4 screws circled in the first picture holding the motherboard down.
    • Now remove the four screw circled in the second picture along with their plastic components.
    • Be careful when removing the plastic part holding the speaker in so as not to rip the speaker wire
  5. Polaroid P902 LCD and Digitizer  Replacement, Removing the Digitizer: passo 5, imagem 1 %32 Polaroid P902 LCD and Digitizer  Replacement, Removing the Digitizer: passo 5, imagem 2 %32 Polaroid P902 LCD and Digitizer  Replacement, Removing the Digitizer: passo 5, imagem 3 %32
    • Flip the tablet over gently, then applying slight pressure on the left hand side lift the digitizer from the LCD
    • it should just lift right off. However you may need to do a bit of wiggling. Don't stress if it doesn't drop right off.
  6. Polaroid P902 LCD and Digitizer  Replacement, ALMOST THERE!!: passo 6, imagem 1 %32 Polaroid P902 LCD and Digitizer  Replacement, ALMOST THERE!!: passo 6, imagem 2 %32 Polaroid P902 LCD and Digitizer  Replacement, ALMOST THERE!!: passo 6, imagem 3 %32
    • Now go around the edges of the metal and release the metal tabs holding the LCD in place
    • I used an iSesamo to do this, made it super easy
    • On the left side of the LCD screen after removing the top metal plate you will see a strip of adhesive, remove it and your almost done
  7. Polaroid P902 LCD and Digitizer  Replacement, FINALLY!!: passo 7, imagem 1 %32 Polaroid P902 LCD and Digitizer  Replacement, FINALLY!!: passo 7, imagem 2 %32
    • Now lift the LCD straight up and out of the bottom casing and you're halfway through the repair :D
    • Now insert the new LCD and reverse the steps. Pat yourself on the back o grab some snacks and check out your like new tablet.
Conclusão
Aj Jones
Membro desde: 04/15/18
1 Reputação
Autoria de 1 guia
Equipe
Loading.. Game Repairs Membro de Loading.. Game Repairs
Business
1 Membro
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 238
