Pular para o conteúdo principal
Introdução
The charging port is the component that you plug the charger into. It allows the battery to get charged and provides electricity for the device. Since replacing this part can cause damage to other part of the device if the soldering isn't properly done, one needs to be careful when soldering.
  1. Using the PH00 screwdriver, remove the two 4mm screws located on both the left and right sides of the charging port on the bottom of the tablet.
    • Using the PH00 screwdriver, remove the two 4mm screws located on both the left and right sides of the charging port on the bottom of the tablet.
  2. Using the plastic opening tool, insert it into the crease where the glass screen meets the housing of the rest of the tablet. Once inserted, keep inserted and run along the edges to separate the plastic clips from each other to dislodge the back plastic away from the glass and internal components.
    • Using the plastic opening tool, insert it into the crease where the glass screen meets the housing of the rest of the tablet. Once inserted, keep inserted and run along the edges to separate the plastic clips from each other to dislodge the back plastic away from the glass and internal components.
  3. Using the PH00 screwdriver, unscrew the four 4.4 mm screws that are anchoring the circuit board down to the rest of the tablet.
    • Using the PH00 screwdriver, unscrew the four 4.4 mm screws that are anchoring the circuit board down to the rest of the tablet.
  4. Using your fingernail, gently lift up the connectors on the two tabs that are holding the ribbons in place to the circuit board.
    • Using your fingernail, gently lift up the connectors on the two tabs that are holding the ribbons in place to the circuit board.
    • Be careful when pulling out or reconnecting the ribbons, since if the ribbon or connectors break, they are hard to fix.
  5. Using a soldering iron, desolder the points circled on the picture until the solder has liquefied enough to be able to remove the wires from the circuit board. When using the soldering iron, be careful not to cause damage to the motherboard. When using the soldering iron, be careful not to cause damage to the motherboard.
    • Using a soldering iron, desolder the points circled on the picture until the solder has liquefied enough to be able to remove the wires from the circuit board.
    • When using the soldering iron, be careful not to cause damage to the motherboard.
  6. Place the tip of the soldering iron on the four points circled in the image long enough to liquefy the surrounding solder. Place the tip of the soldering iron on the four points circled in the image long enough to liquefy the surrounding solder.
    • Place the tip of the soldering iron on the four points circled in the image long enough to liquefy the surrounding solder.
  7. Using tweezers, remove the charging port from the circuit board.
    • Using tweezers, remove the charging port from the circuit board.
    • This should be done quickly as the solder will begin to solidify.
Conclusão
Trent Moskwinski
Membro desde: 26-03-2018
145 reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G2, Harley Spring 2018 Membro de IUPUI, Team S2-G2, Harley Spring 2018
IUPUI-HARLEY-S18S2G2
3 Membros
4 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 145
