Ir para o conteúdo principal
Polaroid Onestep Close Up Shutter Switch Replacement
O que você precisa
  1. Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: passo 1, imagem 1 %32 Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: passo 1, imagem 2 %32 Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: passo 1, imagem 3 %32
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Shutter Switch Replacement, Opening Film Tray: passo 2, imagem 1 %32 Polaroid Onestep Close Up Shutter Switch Replacement, Opening Film Tray: passo 2, imagem 2 %32
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: passo 3, imagem 1 %32 Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: passo 3, imagem 2 %32 Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: passo 3, imagem 3 %32
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: passo 4, imagem 1 %32 Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: passo 4, imagem 2 %32 Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: passo 4, imagem 3 %32
    • After the face plate is off, the shutter switch should slide out easily.
Conclusão
3 outras pessoas executaram este guia.
Tyler OBrien
Membro desde: 09/22/14
627 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 3-5, Brown Fall 2014 Membro de USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 Membros
Autoria de 6 guias
2Comentários do guia
where did you get the replacement parts for this?
Jacob Sokolove - Responder Compartilhar
I’d love to find a new shutter piece..
Joni Korkkula - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 4,757
