Ir para o conteúdo principal
Polaroid Onestep Close Up Primary Lens Replacement
O que você precisa
  1. Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: passo 1, imagem 1 %32 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: passo 1, imagem 2 %32 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: passo 1, imagem 3 %32
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: passo 2, imagem 1 %32 Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: passo 2, imagem 2 %32
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: passo 3, imagem 1 %32 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: passo 3, imagem 2 %32 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: passo 3, imagem 3 %32
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Primary Lens Replacement, Primary Lens: passo 4, imagem 1 %32
    • Once the front assembly is removed, the primary lens should be exposed without any trouble.
  5. Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: passo 5, imagem 1 %32 Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: passo 5, imagem 2 %32
    • Use your spudger to leverage the lens from the groove at the top (red).
    • Pry the lens loose. It may pop out, so have a method in place to prevent it from dropping.
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 3-5, Brown Fall 2014 Membro de USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 1,420
