Ir para o conteúdo principal
Polaroid OneStep 2 Lens Replacement
O que você precisa
  1. Polaroid OneStep 2 Lens Replacement, Lens: passo 1, imagem 1 %32 Polaroid OneStep 2 Lens Replacement, Lens: passo 1, imagem 2 %32 Polaroid OneStep 2 Lens Replacement, Lens: passo 1, imagem 3 %32
    • Unscrew the four Phillips #0 5 mm screws on the base of the camera.
    • Remove the two pieces of the base.
  2. Polaroid OneStep 2 Lens Replacement: passo 2, imagem 1 %32 Polaroid OneStep 2 Lens Replacement: passo 2, imagem 2 %32 Polaroid OneStep 2 Lens Replacement: passo 2, imagem 3 %32
    • Remove the four Phillips #0 5mm screws on the top of the inside base piece.
    • Remove the Phillips #0 5mm two screws on the bottom of the inside base piece nearer the strap.
  3. Polaroid OneStep 2 Lens Replacement: passo 3, imagem 1 %32
    • Remove the black inside base piece.
  4. Polaroid OneStep 2 Lens Replacement: passo 4, imagem 1 %32 Polaroid OneStep 2 Lens Replacement: passo 4, imagem 2 %32
    • With force separate the white front piece from the back of the camera. You will use your hands and pull it apart.
  5. Polaroid OneStep 2 Lens Replacement: passo 5, imagem 1 %32 Polaroid OneStep 2 Lens Replacement: passo 5, imagem 2 %32 Polaroid OneStep 2 Lens Replacement: passo 5, imagem 3 %32
    • Remove the two Phillips #0 3mm screws on the black ring holding the lens in place and remove the ring.
  6. Polaroid OneStep 2 Lens Replacement: passo 6, imagem 1 %32 Polaroid OneStep 2 Lens Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the clear plastic lens with tweezers.
Conclusão
1Comentário do guia
I followed this guide to a T, but it stops right before the replacement. I can even see the cracked lense in the last photo beneath the plastic lense you removed. How would one remove that internal lense and replace it?
JAD - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 38
Ao todo: 8,357
