Ir para o conteúdo principal
Polaroid One-Step 600 Lens Replacement
O que você precisa
  1. Polaroid One-Step 600 Lens Replacement, Lens: passo 1, imagem 1 %32 Polaroid One-Step 600 Lens Replacement, Lens: passo 1, imagem 2 %32 Polaroid One-Step 600 Lens Replacement, Lens: passo 1, imagem 3 %32
    • Open the flash compartment of the camera so it makes a 30 degree angle with the horizontal.
  2. Polaroid One-Step 600 Lens Replacement: passo 2, imagem 1 %32 Polaroid One-Step 600 Lens Replacement: passo 2, imagem 2 %32 Polaroid One-Step 600 Lens Replacement: passo 2, imagem 3 %32
    • Separate the flash section of the camera from the main body by unhooking the sides with the spudger.
    • BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
  3. Polaroid One-Step 600 Lens Replacement: passo 3, imagem 1 %32 Polaroid One-Step 600 Lens Replacement: passo 3, imagem 2 %32 Polaroid One-Step 600 Lens Replacement: passo 3, imagem 3 %32
    • Fully open the battery/ cartridge compartment by sliding the side tab toward you.
  4. Polaroid One-Step 600 Lens Replacement: passo 4, imagem 1 %32 Polaroid One-Step 600 Lens Replacement: passo 4, imagem 2 %32 Polaroid One-Step 600 Lens Replacement: passo 4, imagem 3 %32
    • Insert spudger in between face of camera and sides where the four tabs are located.
    • BE CAREFUL! The button that is pressed to take a picture may pop out of the camera at this step.
  5. Polaroid One-Step 600 Lens Replacement: passo 5, imagem 1 %32 Polaroid One-Step 600 Lens Replacement: passo 5, imagem 2 %32
    • Once tabs are released, pull face of camera straight out.
  6. Polaroid One-Step 600 Lens Replacement: passo 6, imagem 1 %32
    • Use spudger to twist the notch on the lens into the opening to remove it.
  7. Polaroid One-Step 600 Lens Replacement: passo 7, imagem 1 %32 Polaroid One-Step 600 Lens Replacement: passo 7, imagem 2 %32
    • Carefully use spudger to release lens, then lift lens out of camera with fingers.
    • CAUTION: LENS MAY POP OUT OF CAMERA; REMOVE CAREFULLY.
  8. Polaroid One-Step 600 Lens Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    Microfiber Cleaning Cloths
    $3.99
    • Clean old lens with a microfiber cloth or get a new lens to put back into the camera.
Conclusão
8 outras pessoas executaram este guia.
Doug Jimenez
Membro desde: 01/21/10
556 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 16-31, Maness Winter 2010 Membro de Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 Membros
Autoria de 9 guias
1Comentário do guia
Hi, since you seem to know stuff about Polaroid cameras, I was wondering if you could help me figure out what is wrong with mine. I have a Polaroid Instant One-Step and whenever I take pictures, they never fully develop. They are a blue-ish hue and are never clear. Is this because of the lens do you think? Or something completely different?
Thanks
H.Rose - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 33
Ao todo: 16,874
