Ir para o conteúdo principal
Polaroid Cube Lens Replacement
O que você precisa
  1. Polaroid Cube Lens Replacement, Battery: passo 1, imagem 1 %32
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Lens Replacement: passo 2, imagem 1 %32
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Lens Replacement: passo 3, imagem 1 %32
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Lens Replacement: passo 4, imagem 1 %32 Polaroid Cube Lens Replacement: passo 4, imagem 2 %32
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Lens Replacement: passo 5, imagem 1 %32
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Lens Replacement: passo 6, imagem 1 %32
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Lens Replacement: passo 7, imagem 1 %32 Polaroid Cube Lens Replacement: passo 7, imagem 2 %32
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Lens Replacement: passo 8, imagem 1 %32 Polaroid Cube Lens Replacement: passo 8, imagem 2 %32 Polaroid Cube Lens Replacement: passo 8, imagem 3 %32
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Lens Replacement: passo 9, imagem 1 %32 Polaroid Cube Lens Replacement: passo 9, imagem 2 %32
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Lens Replacement: passo 10, imagem 1 %32
    • Gently remove the battery pin connector from the circuit board.
  11. Polaroid Cube Lens Replacement, Lens: passo 11, imagem 1 %32 Polaroid Cube Lens Replacement, Lens: passo 11, imagem 2 %32
    • Use a J00 screwdriver to unscrew the two circled 3.5mm Phillips-head screws from the circuit board.
  12. Polaroid Cube Lens Replacement: passo 12, imagem 1 %32 Polaroid Cube Lens Replacement: passo 12, imagem 2 %32
    • Use a J00 head screwdriver to unscrew the two 3.5mm screws from the circuit board.
  13. Polaroid Cube Lens Replacement: passo 13, imagem 1 %32
    • Remove the lens from the unscrewed circuit board and replace the broken lens.
Conclusão
4 outras pessoas executaram este guia.
Grant Baldwin
Membro desde: 09/29/16
685 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-2, Harley Fall 2016 Membro de IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 Membros
Autoria de 3 guias
2Comentários do guia
Where can I find a replacement lens for the cube+? I broke the bubble part of the lens
Ben McAlister - Responder
Maybe is posable replace wider view angle lens ? original looks like fpv camera lens foxeer or runcam micro. Possibly Caddx micro cam lens
starsas777 - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 2,490
