Ir para o conteúdo principal
Polaroid A10 Front/Back Camera Replacement
O que você precisa
  1. Polaroid A10 Front/Back Camera Replacement, Back Cover: passo 1, imagem 1 %32 Polaroid A10 Front/Back Camera Replacement, Back Cover: passo 1, imagem 2 %32 Polaroid A10 Front/Back Camera Replacement, Back Cover: passo 1, imagem 3 %32
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Front/Back Camera Replacement, Battery: passo 2, imagem 1 %32 Polaroid A10 Front/Back Camera Replacement, Battery: passo 2, imagem 2 %32 Polaroid A10 Front/Back Camera Replacement, Battery: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
    • It is better to use a plastic card if you have one.
    • Gently lift up the battery as you continue to separate the glue from the battery.
    • Lift up just enough to see where the glue is, so that you don't bend the battery.
    • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
  3. Polaroid A10 Front/Back Camera Replacement: passo 3, imagem 1 %32 Polaroid A10 Front/Back Camera Replacement: passo 3, imagem 2 %32 Polaroid A10 Front/Back Camera Replacement: passo 3, imagem 3 %32
  4. Polaroid A10 Front/Back Camera Replacement: passo 4, imagem 1 %32
    • Gently lift the battery up and out of the device.
  5. Polaroid A10 Front/Back Camera Replacement, Front/Back Camera: passo 5, imagem 1 %32
    • The camera head is located on the upper middle section of the device, close to the battery.
  6. Polaroid A10 Front/Back Camera Replacement: passo 6, imagem 1 %32 Polaroid A10 Front/Back Camera Replacement: passo 6, imagem 2 %32
    • Start by locating the two left and right screws which hold the camera head in place.
    • Using the Phillip's 000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
  7. Polaroid A10 Front/Back Camera Replacement: passo 7, imagem 1 %32 Polaroid A10 Front/Back Camera Replacement: passo 7, imagem 2 %32 Polaroid A10 Front/Back Camera Replacement: passo 7, imagem 3 %32
    • Locate the camera ribbon cable that is connected to the motherboard.
    • With a spudger, remove the camera ribbon cable base from the motherboard connector.
    • With one finger, delicately remove the camera ribbon cable by sliding down.
Conclusão
Shilpa Verma
Membro desde: 01/22/15
353 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team 3-3, Rose Winter 2015 Membro de UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 204
