Ir para o conteúdo principal
Polar V800 Waterproofing Seal Replacement
O que você precisa
  1. Polar V800 Waterproofing Seal Replacement, Waterproofing Seal: passo 1, imagem 1 %32 Polar V800 Waterproofing Seal Replacement, Waterproofing Seal: passo 1, imagem 2 %32
    • In this guide, the wrist band of the Polar V800 is removed for a clear view of the back panel. If you find it helpful, you may want to remove the wrist strap. Please reference the Watch Band Replacement guide for removal instructions if you wish to do so.
    • Ensure your Polar V800 sports watch is powered off before continuing.
    • Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
  2. Polar V800 Waterproofing Seal Replacement: passo 2, imagem 1 %32 Polar V800 Waterproofing Seal Replacement: passo 2, imagem 2 %32 Polar V800 Waterproofing Seal Replacement: passo 2, imagem 3 %32
    • Gently separate the watch housing from the back panel.
    • The watch should come apart easily after removing the screws. If you experience difficulties separating the housing and and back cover, use a spudger to gently pry apart the back panel and the button and screen protector housing.
  3. Polar V800 Waterproofing Seal Replacement: passo 3, imagem 1 %32 Polar V800 Waterproofing Seal Replacement: passo 3, imagem 2 %32
    • The waterproofing seal is the red, elastic band that surrounds the display of the watch.
    • Remove the waterproofing seal.
    • During reassembly, align the red seal in the groove surrounding the glass screen on the main watch housing to ensure a watertight seal.
Conclusão
5 outras pessoas executaram este guia.
Jarod Lyles
Membro desde: 04/18/18
833 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S17-G6, Livingston Spring 2018 Membro de Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
Membros da 4
Autoria de 8 guias
2 comentários
Wo kann ich eine neue rote? Abdichtung für Polar V 800 kaufen?
Noa Schulz - Responder
Bitte kurze Info.
Danke
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 29
Duração total: 3,015
