Ir para o conteúdo principal
Polar V800 Display Replacement
O que você precisa
  1. Polar V800 Display Replacement, Waterproofing Seal: passo 1, imagem 1 %32 Polar V800 Display Replacement, Waterproofing Seal: passo 1, imagem 2 %32
    • In this guide, the wrist band of the Polar V800 is removed for a clear view of the back panel. If you find it helpful, you may want to remove the wrist strap. Please reference the Watch Band Replacement guide for removal instructions if you wish to do so.
    • Ensure your Polar V800 sports watch is powered off before continuing.
    • Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
  2. Polar V800 Display Replacement: passo 2, imagem 1 %32 Polar V800 Display Replacement: passo 2, imagem 2 %32 Polar V800 Display Replacement: passo 2, imagem 3 %32
    • Gently separate the watch housing from the back panel.
    • The watch should come apart easily after removing the screws. If you experience difficulties separating the housing and and back cover, use a spudger to gently pry apart the back panel and the button and screen protector housing.
  3. Polar V800 Display Replacement: passo 3, imagem 1 %32 Polar V800 Display Replacement: passo 3, imagem 2 %32
    • The waterproofing seal is the red, elastic band that surrounds the display of the watch.
    • Remove the waterproofing seal.
    • During reassembly, align the red seal in the groove surrounding the glass screen on the main watch housing to ensure a watertight seal.
  4. Polar V800 Display Replacement, Display: passo 4, imagem 1 %32 Polar V800 Display Replacement, Display: passo 4, imagem 2 %32
    • Place a T5 torque screwdriver in the upper right and lower left diagonal 4mm screws that hold the white plastic down and rotate the screwdriver to the left, removing the screws.
  5. Polar V800 Display Replacement: passo 5, imagem 1 %32 Polar V800 Display Replacement: passo 5, imagem 2 %32
    • Lift the display from the board from the top side of the watch, revealing the display connectors underneath.
  6. Polar V800 Display Replacement: passo 6, imagem 1 %32 Polar V800 Display Replacement: passo 6, imagem 2 %32 Polar V800 Display Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, gently pull the display wiring out of the two connectors that attach the display to the motherboard.
    • If the wiring isn't coming out very easily, try wiggling it as you pull it out.
Conclusão
4 outras pessoas executaram este guia.
Jarod Lyles
Membro desde: 04/18/18
835 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S17-G6, Livingston Spring 2018 Membro de Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 Membros
Autoria de 8 guias
15Comentários do guia
Please tell me where can I found spare parts for polar v800 ( motherboard,display)
Thank you
Dimitris Karantonis - Responder
Por sin la encontré. Lleva una Sharp LS013B7DH03
ivan.salson -
Please tell me where can I found spare parts for polar v800 ( motherboard,display, also the case and waterproof seal )
Thank you
Alban Cambronero - Responder
I need to bought a lcd for this watch, someone knows where i can buy it ? Best regards
antonio Fernandez - Responder
Same question as above.
Aki Ala-Salomäki - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 84
Ao todo: 9,597
