Ir para o conteúdo principal
Polar V800 Charging Port Cover Replacement
O que você precisa
  1. Polar V800 Charging Port Cover Replacement, Watch Band: passo 1, imagem 1 %32 Polar V800 Charging Port Cover Replacement, Watch Band: passo 1, imagem 2 %32 Polar V800 Charging Port Cover Replacement, Watch Band: passo 1, imagem 3 %32
    • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
    • Completely pull out the pins.
    • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
    • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
  2. Polar V800 Charging Port Cover Replacement: passo 2, imagem 1 %32 Polar V800 Charging Port Cover Replacement: passo 2, imagem 2 %32 Polar V800 Charging Port Cover Replacement: passo 2, imagem 3 %32
    • To remove the watch band, pull each end of the watch band away from the watch frame.
  3. Polar V800 Charging Port Cover Replacement, Charging Port Cover: passo 3, imagem 1 %32 Polar V800 Charging Port Cover Replacement, Charging Port Cover: passo 3, imagem 2 %32 Polar V800 Charging Port Cover Replacement, Charging Port Cover: passo 3, imagem 3 %32
    • Take off the charging port cover.
Conclusão
Uma outra pessoa concluiu este guia.
Nick B.
Membro desde: 04/29/18
387 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S17-G6, Livingston Spring 2018 Membro de Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
Membros da 4
Autoria de 8 guias
Um comentário
where does not procure the battery port cover ?
Chenthill P - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 15
Duração total: 2,939
