Ir para o conteúdo principal
Polar M400 Watch Screen Replacement
O que você precisa
  1. Polar M400 Watch Screen Replacement, Wrist Strap: passo 1, imagem 1 %32
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
  2. Polar M400 Watch Screen Replacement: passo 2, imagem 1 %32 Polar M400 Watch Screen Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
  3. Polar M400 Watch Screen Replacement: passo 3, imagem 1 %32
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
  4. Polar M400 Watch Screen Replacement, Battery: passo 4, imagem 1 %32
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  5. Polar M400 Watch Screen Replacement: passo 5, imagem 1 %32 Polar M400 Watch Screen Replacement: passo 5, imagem 2 %32
    • Gently remove the backing from the watch.
  6. Polar M400 Watch Screen Replacement: passo 6, imagem 1 %32 Polar M400 Watch Screen Replacement: passo 6, imagem 2 %32
    Comprar
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
  7. Polar M400 Watch Screen Replacement, Screen: passo 7, imagem 1 %32 Polar M400 Watch Screen Replacement, Screen: passo 7, imagem 2 %32
    • Detach the screen from the screen protector using a PH000 screwdriver.
  8. Polar M400 Watch Screen Replacement: passo 8, imagem 1 %32 Polar M400 Watch Screen Replacement: passo 8, imagem 2 %32
    • Attach a new screen to the screen protector.
    • Make sure that the charging port remains accessible, as it can easily become detached during the replacement.
Conclusão
5 outras pessoas executaram este guia.
Nicholas Sanders
Membro desde: 09/28/17
513 Reputação
Autoria de 2 guias
Equipe
10 comentários
Hi, where can i buy the replacement?
Thanks
Mario Sánchez-Barriga Marín - Responder
hi,where can I buy the usb replacement.
GamesFISH_1989 - Responder
Hi, were can i buy the replacement. Thanks
Julien Genon - Responder
https://www.allsystem.cz/
I bought a connector USB there… Maybe can be interesting for someone else…
manuel caudera - Responder
hello manuel,
i tried to order from the web site you specified, but it looks like they are not delivering in france,
cna you please tell me where else i can order this peice
Mathieu Poncet -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 71
Duração total: 9,200
