Ir para o conteúdo principal
Polar M400 Watch Battery Replacement
O que você precisa
  1. Polar M400 Watch Battery Replacement, Wrist Strap: passo 1, imagem 1 %32
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
  2. Polar M400 Watch Battery Replacement: passo 2, imagem 1 %32 Polar M400 Watch Battery Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
  3. Polar M400 Watch Battery Replacement: passo 3, imagem 1 %32
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
  4. Polar M400 Watch Battery Replacement, Battery: passo 4, imagem 1 %32
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  5. Polar M400 Watch Battery Replacement: passo 5, imagem 1 %32 Polar M400 Watch Battery Replacement: passo 5, imagem 2 %32
    • Gently remove the backing from the watch.
  6. Polar M400 Watch Battery Replacement: passo 6, imagem 1 %32 Polar M400 Watch Battery Replacement: passo 6, imagem 2 %32
    Comprar
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
Conclusão
15 outras pessoas executaram este guia.
Nicholas Sanders
Membro desde: 09/28/17
513 Reputação
Autoria de 2 guias
Equipe
25 comentários
Hello, thanks for the details !
The most tricky part: find the right spare part. I can’t find a replacement battery that could fit the original dimensions with reasonnable capacity.
Do you have any lead?
Vincent - Responder
In case if anyone is still looking for the spare part I have just replaced my M400 battery with this one: https://www.aliexpress.com/item/10050045...
Replacement instructions were detailed enough to get my watch to work again.
Roman -
Bonjour
Pourriez-vous m’indiquer ou je peux acheter une batterie compatible ou originale
Merci à vous
ducellier - Responder
where can i buy a batery for my polar m400? Link please. Thanks
lsmi_21 - Responder
Once the battery is changed, the M400 does not work. Do you have to press any combination of keys?
lojobis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 45
Últimos 30 dias: 202
Duração total: 30,144
