Ir para o conteúdo principal
Poin2 Chromebook 11 Motherboard Replacement
O que você precisa
  1. Poin2 Chromebook 11 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Poin2 Chromebook 11 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Power down the Poin2 Chrombook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
  2. Poin2 Chromebook 11 Motherboard Replacement: passo 2, imagem 1 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 2, imagem 2 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 2, imagem 3 %32
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Motherboard Replacement: passo 3, imagem 1 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 3, imagem 2 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 3, imagem 3 %32
    • Unplug the white 8-wire battery connector using a spudger to push the two L-shaped clips out of the socket.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Motherboard Replacement: passo 4, imagem 1 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 4, imagem 2 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 4, imagem 3 %32
    • Use a spudger (or fingertips) to flip up the plastic clamps that hold down the two ribbon cables connected to the motherboard.
    • Pull the cables from their sockets.
  5. Poin2 Chromebook 11 Motherboard Replacement: passo 5, imagem 1 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 5, imagem 2 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the coaxial connectors from the motherboard using tweezers (or a spudger) to "snap" off the connectors from their sockets.
    • To reinstall, hold the connectors in place and gently press them straight down. The connectors will “snap” back in place.
  6. Poin2 Chromebook 11 Motherboard Replacement: passo 6, imagem 1 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 6, imagem 2 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 6, imagem 3 %32
    • Disconnect the speaker and charging port cables by pulling the connectors out of their sockets.
    • The connectors may require a spudger to help with release from the sockets.
  7. Poin2 Chromebook 11 Motherboard Replacement: passo 7, imagem 1 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 7, imagem 2 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 7, imagem 3 %32
    • Disconnect the LCD screen connector from the motherboard using a spudger.
  8. Poin2 Chromebook 11 Motherboard Replacement: passo 8, imagem 1 %32 Poin2 Chromebook 11 Motherboard Replacement: passo 8, imagem 2 %32
    • Use a #000 Phillips screwdriver and remove the twelve 4mm screws that hold the motherboard.
  9. Poin2 Chromebook 11 Motherboard Replacement: passo 9, imagem 1 %32
    • Use a plastic opening tool and pry around the edges of the motherboard to release.
  10. Poin2 Chromebook 11 Motherboard Replacement: passo 10, imagem 1 %32
    • Lift and remove the motherboard away from the frame.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 473
