Ir para o conteúdo principal
Poin2 Chromebook 11 Battery Replacement
O que você precisa
  1. Poin2 Chromebook 11 Battery Replacement, Battery: passo 1, imagem 1 %32 Poin2 Chromebook 11 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
  2. Poin2 Chromebook 11 Battery Replacement: passo 2, imagem 1 %32 Poin2 Chromebook 11 Battery Replacement: passo 2, imagem 2 %32 Poin2 Chromebook 11 Battery Replacement: passo 2, imagem 3 %32
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Battery Replacement: passo 3, imagem 1 %32 Poin2 Chromebook 11 Battery Replacement: passo 3, imagem 2 %32 Poin2 Chromebook 11 Battery Replacement: passo 3, imagem 3 %32
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Battery Replacement: passo 4, imagem 1 %32 Poin2 Chromebook 11 Battery Replacement: passo 4, imagem 2 %32
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
  5. Poin2 Chromebook 11 Battery Replacement: passo 5, imagem 1 %32
    • Lift the battery from the frame.
Conclusão
To reassemble your Poin2 Chromebook 11, follow these instructions in reverse order.
Um comentário
An important piece of information missing is the battery replacement number.
a Google search brings up no references.
Marty Sharik - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 879
