Ir para o conteúdo principal
Pocket Knife Wooden Casing Replacement
O que você precisa
  1. Pocket Knife Wooden Casing Replacement, Wooden Casing: passo 1, imagem 1 %32 Pocket Knife Wooden Casing Replacement, Wooden Casing: passo 1, imagem 2 %32
    • Trace the knife outline onto wood.
  2. Pocket Knife Wooden Casing Replacement: passo 2, imagem 1 %32 Pocket Knife Wooden Casing Replacement: passo 2, imagem 2 %32
    • Cut out the outline of the wood.
    • Cut the height of the wood to the correct measurement.
  3. Pocket Knife Wooden Casing Replacement: passo 3, imagem 1 %32 Pocket Knife Wooden Casing Replacement: passo 3, imagem 2 %32
    • Sand the wood so that it is smooth and free of hard edges.
    • For the best result, sand in the direction of the grain as much as possible.
  4. Pocket Knife Wooden Casing Replacement: passo 4, imagem 1 %32 Pocket Knife Wooden Casing Replacement: passo 4, imagem 2 %32 Pocket Knife Wooden Casing Replacement: passo 4, imagem 3 %32
    • Stain and polish the wood so that it is reflects the other side of the knife.
    • Apply another coat after the first coat dries if you want a darker stain.
    • If you get the Stain and Polish on your skin, your skin might be stained for a few days. In this case, make sure you wash thoroughly; Stain and Polish is only toxic if it is ingested.
  5. Pocket Knife Wooden Casing Replacement: passo 5, imagem 1 %32 Pocket Knife Wooden Casing Replacement: passo 5, imagem 2 %32
    • Drill four small holes that will go over the extruded parts of the knife.
    • You can accurately mark the positions of the holes by coloring the screw heads with sharpie then stamping them into the wood.
  6. Pocket Knife Wooden Casing Replacement: passo 6, imagem 1 %32 Pocket Knife Wooden Casing Replacement: passo 6, imagem 2 %32 Pocket Knife Wooden Casing Replacement: passo 6, imagem 3 %32
    • Glue the wood to the knife and clean any hard edges or excess glue that comes from this step.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 365
