Ir para o conteúdo principal
Pneumatic Door Closer Replacement
O que você precisa
  1. Pneumatic Door Closer Replacement, Pneumatic Door Closer: passo 1, imagem 1 %32 Pneumatic Door Closer Replacement, Pneumatic Door Closer: passo 1, imagem 2 %32
    • Identify the broken part of the door.
  2. Pneumatic Door Closer Replacement: passo 2, imagem 1 %32 Pneumatic Door Closer Replacement: passo 2, imagem 2 %32
    • Remove the screws from the inner brackets that connect to the door closer using a screwdriver.
  3. Pneumatic Door Closer Replacement: passo 3, imagem 1 %32 Pneumatic Door Closer Replacement: passo 3, imagem 2 %32 Pneumatic Door Closer Replacement: passo 3, imagem 3 %32
    • Remove the screws from the outer bracket that connect to the door closer using a screwdriver.
  4. Pneumatic Door Closer Replacement: passo 4, imagem 1 %32 Pneumatic Door Closer Replacement: passo 4, imagem 2 %32
    • Install the inner bracket that attaches to the door closer by screwing the inner part into the wall using a screwdriver.
  5. Pneumatic Door Closer Replacement: passo 5, imagem 1 %32 Pneumatic Door Closer Replacement: passo 5, imagem 2 %32 Pneumatic Door Closer Replacement: passo 5, imagem 3 %32
    • Plug the smallest included screw into the inner bracket to attach the door closer.
  6. Pneumatic Door Closer Replacement: passo 6, imagem 1 %32 Pneumatic Door Closer Replacement: passo 6, imagem 2 %32 Pneumatic Door Closer Replacement: passo 6, imagem 3 %32
    • Close the door.
    • Install the outer bracket that attaches to the door closer by screwing it into the door using a screwdriver.
  7. Pneumatic Door Closer Replacement: passo 7, imagem 1 %32 Pneumatic Door Closer Replacement: passo 7, imagem 2 %32 Pneumatic Door Closer Replacement: passo 7, imagem 3 %32
    • Attach the door closer into the installed outer bracket by plugging the larger included screw into the inner part.
  8. Pneumatic Door Closer Replacement: passo 8, imagem 1 %32 Pneumatic Door Closer Replacement: passo 8, imagem 2 %32
    • Make sure the door closes and opens properly.
    • Adjust the hydraulics by loosening or tightening the screw on the top of the hydraulic axle to have optimal performance.
Linha de Chegada
Abdullah Kaddura
Membro desde: 02/24/21
157 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 659
