Ir para o conteúdo principal
Plum Optimax 10 Motherboard Replacement
O que você precisa
  1. Plum Optimax 10 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Plum Optimax 10 Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Motherboard Replacement: passo 2, imagem 1 %32 Plum Optimax 10 Motherboard Replacement: passo 2, imagem 2 %32
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 Plum Optimax 10 Motherboard Replacement, Motherboard: passo 3, imagem 2 %32
    • Use flathead screwdriver tool to remove the three 2.5 mm screws shown in the photo. Two screws are located at the base of the motherboard and there is one screw located at the top.
  4. Plum Optimax 10 Motherboard Replacement: passo 4, imagem 1 %32
    • Once screws are removed, carefully remove the motherboard out of encasing.
Conclusão
Uma outra pessoa concluiu este guia.
Samantha Wright
Membro desde: 11/06/18
243 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G4, Hovde Fall 2018 Membro de IUPUI, Team S1-G4, Hovde Fall 2018
IUPUI-HOVDE-F18S1G4
Membros da 3
Autoria de 6 guias
Um comentário
This document is incomplete. It does not detail removing the cables connected to the motherboard.
Before the motherboard can be removed from the case, the Digitizer, the LCD and the power and camera cables must also be removed. the speakers, vibrator and Mic can come out with the motherboard.
George Earl Martin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 8
Duração total: 168
