O que você precisa
Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
Use flathead screwdriver tool to remove the three 2.5 mm screws shown in the photo. Two screws are located at the base of the motherboard and there is one screw located at the top.
Gently pop the display out from the display cover by prying around the edges with a plastic opening tool or spudger.
Quase terminado!
Conclusão
