Ir para o conteúdo principal
Playstation Classic Controller Cord Replacement
O que você precisa
  1. Playstation Classic Controller Cord Replacement, Controller Cord: passo 1, imagem 1 %32 Playstation Classic Controller Cord Replacement, Controller Cord: passo 1, imagem 2 %32 Playstation Classic Controller Cord Replacement, Controller Cord: passo 1, imagem 3 %32
    • Turn the controller over so that the screws are facing up.
  2. Playstation Classic Controller Cord Replacement: passo 2, imagem 1 %32
    • Use a small Phillips #0 screwdriver to remove the eight Xmm screws.
    • Make sure to store the screws in a safe place so they are not lost before reassembly.
  3. Playstation Classic Controller Cord Replacement: passo 3, imagem 1 %32 Playstation Classic Controller Cord Replacement: passo 3, imagem 2 %32 Playstation Classic Controller Cord Replacement: passo 3, imagem 3 %32
    • Use the Jimmy tool to take the back part off and get into the controller.
    • It shouldn’t take too much force to remove the back part. Make sure all screws are taken out beforehand so you avoid hurting yourself or damaging the controller.
  4. Playstation Classic Controller Cord Replacement: passo 4, imagem 1 %32
    • You will notice that the controller cord is plugged into a Micro USB port on the controller motherboard.
  5. Playstation Classic Controller Cord Replacement: passo 5, imagem 1 %32 Playstation Classic Controller Cord Replacement: passo 5, imagem 2 %32 Playstation Classic Controller Cord Replacement: passo 5, imagem 3 %32
    • To unplug the cord from the controller motherboard, carefully take the cord out from in between the small pegs that it is nestled into.
    • When unplugging the cord, hold the controller so that no significant pressure is being applied to the motherboard that will damage it.
Conclusão
3 outras pessoas executaram este guia.
Maxwell Webb
Membro desde: 04/22/19
631 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S2-G8, Maness Spring 2019 Membro de Cal Poly, Team S2-G8, Maness Spring 2019
CPSU-MANESS-S19S2G8
Membros da 2
Autoria de 22 guias
2 comentários
Will this fix the controller being unresponsive?
Jamal Saeed - Responder
maybe but It depends
enrique bengaura -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 78
Duração total: 6,098
