Introdução
This guide provides the steps to separate the Playstation 3 motherboard from its metal enclosure. This allows the motherboard to be replaced if necessary.
O que você precisa
Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
Remove the two screws on the front of the power supply.
Unplug the optical drive power cable.
Detach the ribbon cable that connects the optical drive to the motherboard.
Set the optical drive aside.
Remove four black screws (Phillips #2) from the top plate of the motherboard enclosure.
The two, small plates held down by the screws should become loose. Remove these plates.
3 outras pessoas executaram este guia.
