Ir para o conteúdo principal
Playstation 3 Motherboard Enclosure Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Playstation 3 Motherboard Enclosure Replacement, Top Cover: passo 1, imagem 1 %32 Playstation 3 Motherboard Enclosure Replacement, Top Cover: passo 1, imagem 2 %32
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Playstation 3 Motherboard Enclosure Replacement: passo 2, imagem 1 %32
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Playstation 3 Motherboard Enclosure Replacement: passo 3, imagem 1 %32 Playstation 3 Motherboard Enclosure Replacement: passo 3, imagem 2 %32
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Playstation 3 Motherboard Enclosure Replacement: passo 4, imagem 1 %32 Playstation 3 Motherboard Enclosure Replacement: passo 4, imagem 2 %32
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. Playstation 3 Motherboard Enclosure Replacement: passo 5, imagem 1 %32 Playstation 3 Motherboard Enclosure Replacement: passo 5, imagem 2 %32 Playstation 3 Motherboard Enclosure Replacement: passo 5, imagem 3 %32
    • You can now lift off the top cover.
  6. Playstation 3 Motherboard Enclosure Replacement, Power Supply: passo 6, imagem 1 %32 Playstation 3 Motherboard Enclosure Replacement, Power Supply: passo 6, imagem 2 %32
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  7. Playstation 3 Motherboard Enclosure Replacement: passo 7, imagem 1 %32
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  8. Playstation 3 Motherboard Enclosure Replacement: passo 8, imagem 1 %32 Playstation 3 Motherboard Enclosure Replacement: passo 8, imagem 2 %32
    • Remove the power supply by lifting it straight up.
  9. Playstation 3 Motherboard Enclosure Replacement, Motherboard Enclosure: passo 9, imagem 1 %32 Playstation 3 Motherboard Enclosure Replacement, Motherboard Enclosure: passo 9, imagem 2 %32
    • Unplug the optical drive power cable.
    • Detach the ribbon cable that connects the optical drive to the motherboard.
    • Set the optical drive aside.
  10. Playstation 3 Motherboard Enclosure Replacement: passo 10, imagem 1 %32 Playstation 3 Motherboard Enclosure Replacement: passo 10, imagem 2 %32
    • Remove three screws (Phillips #2) from the wireless board and antenna.
    • Detach the ribbon cable that connects the wireless board to the motherboard.
  11. Playstation 3 Motherboard Enclosure Replacement: passo 11, imagem 1 %32
    • Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
  12. Playstation 3 Motherboard Enclosure Replacement: passo 12, imagem 1 %32 Playstation 3 Motherboard Enclosure Replacement: passo 12, imagem 2 %32 Playstation 3 Motherboard Enclosure Replacement: passo 12, imagem 3 %32
    • Remove the hard drive door with a spudger.
    • Lift the metal enclosure out of the plastic bottom case.
Conclusão
iDeleted
Membro desde: 07/07/10
2.101 Reputação
Autoria de 39 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 1,913
