Introdução
The whole Playstation 3 is cooled by a single fan on its bottom side. In this guide, we will remove that fan so that it may be cleaned or replaced.
O que você precisa
Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
Remove the two screws on the front of the power supply.
Unplug the optical drive power cable.
Detach the ribbon cable that connects the optical drive to the motherboard.
Set the optical drive aside.
Remove the three screws (Phillips #2).
Disconnect the fan's power cable.
Lift the fan straight up and out.
Uma outra pessoa concluiu este guia.
