Ir para o conteúdo principal
PlayStation Vita Wi-Fi Antenna Replacement
O que você precisa
  1. PlayStation Vita Wi-Fi Antenna Replacement, Case Separation: passo 1, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement, Case Separation: passo 1, imagem 2 %32
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Wi-Fi Antenna Replacement: passo 2, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 2, imagem 2 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 2, imagem 3 %32
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Wi-Fi Antenna Replacement: passo 3, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 3, imagem 2 %32
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Wi-Fi Antenna Replacement: passo 4, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 4, imagem 2 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 4, imagem 3 %32
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Wi-Fi Antenna Replacement: passo 5, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 5, imagem 2 %32
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    One of the shoulder buttons fell out when I was doing this step, along with the piece holding it in place. They go back in just fine when reassembling but make sure that they are oriented properly, of course.
    klung - Responder
  6. PlayStation Vita Wi-Fi Antenna Replacement: passo 6, imagem 1 %32
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Wi-Fi Antenna Replacement: passo 7, imagem 1 %32
    • Free the battery cable by gently prying up on the connection with a spudger.
    Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
    Jimbo Jones - Responder
    This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
    ylimakiminna - Responder
    Yea I messed up there too. Is there a way to fix it?
    Alethia Henry - Responder
    This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
    klung - Responder
    broke the white part
    Benaya Miller - Responder
  8. PlayStation Vita Wi-Fi Antenna Replacement: passo 8, imagem 1 %32
    • Separate the front and rear cases.
  9. PlayStation Vita Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 9, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 9, imagem 2 %32
    • Using the pointy end of a spudger, gently pry the white Wi-Fi antenna cable connecotr off of the wireless card.
    • Deroute the Wi-Fi antenna cable out of the black plastic casing.
  10. PlayStation Vita Wi-Fi Antenna Replacement: passo 10, imagem 1 %32 PlayStation Vita Wi-Fi Antenna Replacement: passo 10, imagem 2 %32
    • Using the pointy end of the spudger, gently pry the Wi-Fi antenna cable connector off of the left button board at the connection.
    • Remove the Wi-Fi antenna cable.
    Why is it the wifi antenna if the cable is connected to the cellular board? it is the primary cellular antenna. the wifi antenna is the 2 small antennas in the upper half of the back case
    Tom Chai - Responder
    Followed the instructions here to open up and check the cabling for the WiFi ( PS Vita no longer connects to WiFi), however I did NOT find any cables except flat ribbon cables. PS Vita model PCH-1003.
    Paul McCulloch - Responder
Conclusão
Brittany McCrigler
Membro desde: 03/05/12
89.865 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.636 guias
4Comentários do guia
what about the ps vita slim 2000 model? ive got no wifi at all but cant see a teardown to find the wifi module
Keegan - Responder
Is WiFi / 3G antenna cable: UFL/IPEX to UFL/IPEX 1.3mm? What is the white cable length?
samohvalov2010 - Responder
Yeah this is not a Wifi antenna cable. The "wireless card" only does 3G and GPS/Glonass. Wifi controller is on the mainboard itself.
computer1up - Responder
^ okay that explains a lot, i thought i was missing parts in my PSV1000 wifi
Bronson - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 88
Ao todo: 8,931
