Ir para o conteúdo principal
PlayStation Vita Speakers Replacement
O que você precisa
  1. PlayStation Vita Speakers Replacement, Case Separation: passo 1, imagem 1 %32 PlayStation Vita Speakers Replacement, Case Separation: passo 1, imagem 2 %32
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Speakers Replacement: passo 2, imagem 1 %32 PlayStation Vita Speakers Replacement: passo 2, imagem 2 %32 PlayStation Vita Speakers Replacement: passo 2, imagem 3 %32
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Speakers Replacement: passo 3, imagem 1 %32 PlayStation Vita Speakers Replacement: passo 3, imagem 2 %32
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Speakers Replacement: passo 4, imagem 1 %32 PlayStation Vita Speakers Replacement: passo 4, imagem 2 %32 PlayStation Vita Speakers Replacement: passo 4, imagem 3 %32
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Speakers Replacement: passo 5, imagem 1 %32 PlayStation Vita Speakers Replacement: passo 5, imagem 2 %32
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    One of the shoulder buttons fell out when I was doing this step, along with the piece holding it in place. They go back in just fine when reassembling but make sure that they are oriented properly, of course.
    klung - Responder
  6. PlayStation Vita Speakers Replacement: passo 6, imagem 1 %32
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Speakers Replacement: passo 7, imagem 1 %32
    • Free the battery cable by gently prying up on the connection with a spudger.
    Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
    Jimbo Jones - Responder
    This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
    ylimakiminna - Responder
    Yea I messed up there too. Is there a way to fix it?
    Alethia Henry - Responder
    This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
    klung - Responder
    broke the white part
    Benaya Miller - Responder
  8. PlayStation Vita Speakers Replacement: passo 8, imagem 1 %32
    • Separate the front and rear cases.
  9. PlayStation Vita Speakers Replacement, Speakers: passo 9, imagem 1 %32 PlayStation Vita Speakers Replacement, Speakers: passo 9, imagem 2 %32
    • Gently insert a spudger along the side of the speaker on the back casing assembly. Pry the speaker off the casing and remove it.
    • The speaker is adhered to the casing with light tape, which may give the speaker light resistance.
    What is that little connection point for, just above where the speaker sits. it has a single connection point on the side motherboard.
    Chris Ramsay - Responder
Conclusão
3 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.017 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
2 comentários
My Ps vita is still not playing sound with the volume all the way up. Think this could be electrical?
Sarah - Responder
my ps vita 3G model get washed, i dismantle the console and both speakers to let it dry. 1 month later my vita woke up but now the speakers sound bad, is there a way to fix them?
Luis Hernández - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 19
Últimos 30 dias: 89
Duração total: 12,192
