Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide takes you through the process of installing the right shoulder button.
O que você precisa
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
Pry up the right shoulder button casing with a spudger and set it aside.
4 outras pessoas executaram este guia.
5 comentários
Is anyone else experiencing the button getting stuck?
Yes, mine is getting stuck, too. I am hoping a replacement will solve this problem.
aseelau -
i am replacing the whole front part of my vita do to screen cracked and wont turn on, when i put the button back on, how would i do so to make it stick back on? would i need to reglue it or will it stick back on by itself?
