Ir para o conteúdo principal
PlayStation Vita PS Button Replacement
O que você precisa
  1. PlayStation Vita PS Button Replacement, Case Separation: passo 1, imagem 1 %32 PlayStation Vita PS Button Replacement, Case Separation: passo 1, imagem 2 %32
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
    Pergunte ao FixBot
  2. PlayStation Vita PS Button Replacement: passo 2, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 2, imagem 2 %32 PlayStation Vita PS Button Replacement: passo 2, imagem 3 %32
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
    Pergunte ao FixBot
  3. PlayStation Vita PS Button Replacement: passo 3, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 3, imagem 2 %32
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
    Pergunte ao FixBot
  4. PlayStation Vita PS Button Replacement: passo 4, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 4, imagem 2 %32 PlayStation Vita PS Button Replacement: passo 4, imagem 3 %32
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
    Pergunte ao FixBot
  5. PlayStation Vita PS Button Replacement: passo 5, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 5, imagem 2 %32
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    Pergunte ao FixBot
  6. PlayStation Vita PS Button Replacement: passo 6, imagem 1 %32
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
    Pergunte ao FixBot
  7. PlayStation Vita PS Button Replacement: passo 7, imagem 1 %32
    • Free the battery cable by gently prying up on the connection with a spudger.
    Pergunte ao FixBot
  8. PlayStation Vita PS Button Replacement: passo 8, imagem 1 %32
    • Separate the front and rear cases.
    Pergunte ao FixBot
  9. PlayStation Vita PS Button Replacement, Left Shoulder Button: passo 9, imagem 1 %32 PlayStation Vita PS Button Replacement, Left Shoulder Button: passo 9, imagem 2 %32 PlayStation Vita PS Button Replacement, Left Shoulder Button: passo 9, imagem 3 %32
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
    Pergunte ao FixBot
  10. PlayStation Vita PS Button Replacement: passo 10, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 10, imagem 2 %32
    • Remove the translucent, plastic left shoulder button cover.
    Pergunte ao FixBot
  11. PlayStation Vita PS Button Replacement: passo 11, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 11, imagem 2 %32 PlayStation Vita PS Button Replacement: passo 11, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
    Pergunte ao FixBot
  12. PlayStation Vita PS Button Replacement: passo 12, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 12, imagem 2 %32
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
    Pergunte ao FixBot
  13. PlayStation Vita PS Button Replacement, Left Button Board: passo 13, imagem 1 %32 PlayStation Vita PS Button Replacement, Left Button Board: passo 13, imagem 2 %32
    • Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
    • Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
    Pergunte ao FixBot
  14. PlayStation Vita PS Button Replacement: passo 14, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 14, imagem 2 %32 PlayStation Vita PS Button Replacement: passo 14, imagem 3 %32
    • Use a spudger to release the tab between the SIM card reader and the back casing assembly.
    • Lift the SIM card reader off the back casing assembly.
    Pergunte ao FixBot
  15. PlayStation Vita PS Button Replacement: passo 15, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 15, imagem 2 %32
    • Release the plastic tab on the small flex cable socket by prying it up with a spudger.
    • Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
    Pergunte ao FixBot
  16. PlayStation Vita PS Button Replacement: passo 16, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 16, imagem 2 %32
    • Use a spudger to lift up the tab on the large ZIF socket.
    • Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
    Pergunte ao FixBot
  17. PlayStation Vita PS Button Replacement: passo 17, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 17, imagem 2 %32
    • Disconnect the white Wi-Fi antenna cable with a spudger.
    • Remove the Wi-Fi antenna cable.
    Pergunte ao FixBot
  18. PlayStation Vita PS Button Replacement: passo 18, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 18, imagem 2 %32 PlayStation Vita PS Button Replacement: passo 18, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
    • Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
    • Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
    Pergunte ao FixBot
  19. PlayStation Vita PS Button Replacement: passo 19, imagem 1 %32 PlayStation Vita PS Button Replacement: passo 19, imagem 2 %32 PlayStation Vita PS Button Replacement: passo 19, imagem 3 %32
    • Starting from the upper left corner, use a spudger to pry up and remove the left button board.
    Pergunte ao FixBot
  20. PlayStation Vita PS Button Replacement, PS Button: passo 20, imagem 1 %32 PlayStation Vita PS Button Replacement, PS Button: passo 20, imagem 2 %32 PlayStation Vita PS Button Replacement, PS Button: passo 20, imagem 3 %32
    • Using tweezers, peel up and remove the PS button.
    Pergunte ao FixBot
Conclusão
7 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
90.868 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 25.710 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 41
Últimos 30 dias: 222
Ao todo: 13,159
