Ir para o conteúdo principal
PlayStation Vita Battery Replacement
O que você precisa
  1. PlayStation Vita Battery Replacement, Case Separation: passo 1, imagem 1 %32 PlayStation Vita Battery Replacement, Case Separation: passo 1, imagem 2 %32
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Battery Replacement: passo 2, imagem 1 %32 PlayStation Vita Battery Replacement: passo 2, imagem 2 %32 PlayStation Vita Battery Replacement: passo 2, imagem 3 %32
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Battery Replacement: passo 3, imagem 1 %32 PlayStation Vita Battery Replacement: passo 3, imagem 2 %32
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Battery Replacement: passo 4, imagem 1 %32 PlayStation Vita Battery Replacement: passo 4, imagem 2 %32 PlayStation Vita Battery Replacement: passo 4, imagem 3 %32
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Battery Replacement: passo 5, imagem 1 %32 PlayStation Vita Battery Replacement: passo 5, imagem 2 %32
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    One of the shoulder buttons fell out when I was doing this step, along with the piece holding it in place. They go back in just fine when reassembling but make sure that they are oriented properly, of course.
    klung - Responder
  6. PlayStation Vita Battery Replacement: passo 6, imagem 1 %32
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Battery Replacement: passo 7, imagem 1 %32
    • Free the battery cable by gently prying up on the connection with a spudger.
    Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
    Jimbo Jones - Responder
    This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
    ylimakiminna - Responder
    Yea I messed up there too. Is there a way to fix it?
    Alethia Henry - Responder
    This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
    klung - Responder
    broke the white part
    Benaya Miller - Responder
  8. PlayStation Vita Battery Replacement: passo 8, imagem 1 %32
    • Separate the front and rear cases.
  9. PlayStation Vita Battery Replacement, Battery: passo 9, imagem 1 %32 PlayStation Vita Battery Replacement, Battery: passo 9, imagem 2 %32
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
    Using the tabs (I could really only see one) on the side of the retainer proved essential for me to remove it and release the cable. Unless that happened that cable retainer was not moving for me at all. It did come out once the tabs were pressed though they did prove somewhat uncooperative with clicking back into place once I had installed the new battery. Also, watch that the battery’s cable isn’t pinched when you’re putting everything back in place.
    klung - Responder
  10. PlayStation Vita Battery Replacement: passo 10, imagem 1 %32 PlayStation Vita Battery Replacement: passo 10, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
    When reinstalling the battery retaining bar, be sure to insert the bottom end (as shown in the photo) into the slot before driving in the screws. If you just lay it on top, you will crack the bar.
    Lee Johnson - Responder
  11. PlayStation Vita Battery Replacement: passo 11, imagem 1 %32 PlayStation Vita Battery Replacement: passo 11, imagem 2 %32 PlayStation Vita Battery Replacement: passo 11, imagem 3 %32
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
Conclusão
127 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.017 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
27 comentários
Great guide. Only problem is this takes very steady hands (something i do not have)
chavis0704 - Responder
This is a great guide. It allowed me to execute the repair and do so without and damage. Just be careful with the triggers they can move and get caught while closing everything up.
Amon Bouchereau - Responder
how do i know what persent my battery is at
jewon - Responder
Jewon today we have a hack for psvita 3.60 version ONLY !! this allow u download a VPK file that says how much persent your battery is at
brunosapo -
With your Vita connected to your PC and the Content manager application running, on windows right click on the vita and then properties and the battery percentage will show up.
Matthew Michand -
Great guide. Thanks for writing it!
Reiaze - Responder
weeelll I think I have a broken Vita now. Make sure you're not an idiot like me who doesn't know which parts to pull in which direction when trying to free the battery cable.
Well. Didn't take out the memory card after removing battery Aaannndddd now the vita says its not in there.
Emmanuel Brown - Responder
I had the same issue do you think you just need a new memory card? I'm hoping that's all it is even though they aren't cheap it's cheaper than a whole mother vita...
klarson79 -
Yeah, I’d seen warnings about that online. Apparently, when you install a new battery there is a surge of power as everything is reconnected. Removing any cards in any of the slots is advised to prevent damage to them.
klung -
I had the same issue Emmanuel I just need a new card then right?
klarson79 - Responder
Thank you! My son's PS Vita alive again :)
Юрий Иванов - Responder
My PS vita phat is only displaying PlayStation. Logo then shutdown I can't even go through the recovery mode.. Tried most charging method... I tried removing my battery and putting it to a different PS vita unit and it worked fine... Is my battery faulty?
demetrio dario - Responder
So I replaced the battery on my PS Vita 1000. When I try turning it on, an orange light shows up on the PS logo but the device does not turn on. Should I let the new battery charge for a bit before trying again?
ajsanaje - Responder
The iFixit info on the Vita battery product page stated to calibrate the battery before use. Not sure if that has to do with the complications you’re facing but worth considering.
klung -
Are there alternatives to the Spudger and/or Opening Tools that one might already have available from home?
Matthew Conklin - Responder
Worked perfect. Great guide. Thanks!
Jochen Jakob - Responder
My version is different i can’t for the life of me get back panel touch foil into the connector it is really short
limbovampier - Responder
Try to hold the back panela at a closer angle with the console and use a spudger to or tweezers to reach the cable if necessary.
Daniele Carminati -
The socket on the motherboard is different and smaller than on the replacement seems to big and I can't get it to fit
Jesinia Reyna - Responder
I had the same issue. The connector on the new battery is too big for the socket on the motherboard. I've reached out to customer service for support.
camtheham -
My nine-year-old Vita still worked, but its original battery was not in the best condition. I obtained a replacement battery from iFixit and used this guide to install it. It may look daunting at first, but if you study the guide, take your time, and follow the steps carefully, it’s actually pretty straightforward. Having a spudger definitely helps.
Do you know if this will get rid of your jailbreak on your vita?
Daniel Lopez - Responder
nope it wont just gotta rebuild database insert and remove the sd2vita multiple times trial and error.
Chip -
Ok for the most part but way to vague overall with the position of the clips, specially step 7 and 9 which are about basically useless as these are not the most common attachment positions so I had to figure them out, the direction and clip lock points by myself with risk of damaging these critical small connectors and pieces;
Please consider adding red indicators and a glossary of clip lock types and along with it's own release mechanism and clip points.
Thank you
ionX - Responder
While I'm at it, for step 7: the battery connector disconnected upwards instead of sideways, and the release/locks of the clips are on the sides towards the cable side not the connectors;
And for step 9: the plastic piece holding down the battery and rear touchpad connectors in place, the release clips are too the 2 sides right below each little hole, push in from each side from the outside of the piece itself inwards to unclip
(Can be a bit hard to tell since they are so small and being all black)
It's late but I hope you could consider adding such info in in a clearer manner
ionX -
What batteries can be used instead of sp65x?
Nattawat Saelim - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 105
Últimos 7 dias: 774
Últimos 30 dias: 3,727
Duração total: 243,159
