Ir para o conteúdo principal
PlayStation Vita Battery Replacement
O que você precisa
  1. PlayStation Vita Battery Replacement, Case Separation: passo 1, imagem 1 %32 PlayStation Vita Battery Replacement, Case Separation: passo 1, imagem 2 %32
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Battery Replacement: passo 2, imagem 1 %32 PlayStation Vita Battery Replacement: passo 2, imagem 2 %32 PlayStation Vita Battery Replacement: passo 2, imagem 3 %32
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Battery Replacement: passo 3, imagem 1 %32 PlayStation Vita Battery Replacement: passo 3, imagem 2 %32
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Battery Replacement: passo 4, imagem 1 %32 PlayStation Vita Battery Replacement: passo 4, imagem 2 %32 PlayStation Vita Battery Replacement: passo 4, imagem 3 %32
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Battery Replacement: passo 5, imagem 1 %32 PlayStation Vita Battery Replacement: passo 5, imagem 2 %32
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Battery Replacement: passo 6, imagem 1 %32
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Battery Replacement: passo 7, imagem 1 %32
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Battery Replacement: passo 8, imagem 1 %32
    • Separate the front and rear cases.
  9. PlayStation Vita Battery Replacement, Battery: passo 9, imagem 1 %32 PlayStation Vita Battery Replacement, Battery: passo 9, imagem 2 %32
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
  10. PlayStation Vita Battery Replacement: passo 10, imagem 1 %32 PlayStation Vita Battery Replacement: passo 10, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
  11. PlayStation Vita Battery Replacement: passo 11, imagem 1 %32 PlayStation Vita Battery Replacement: passo 11, imagem 2 %32 PlayStation Vita Battery Replacement: passo 11, imagem 3 %32
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
Conclusão
127 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.020 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.299 guias
27 comentários
Great guide. Only problem is this takes very steady hands (something i do not have)
chavis0704 - Responder
This is a great guide. It allowed me to execute the repair and do so without and damage. Just be careful with the triggers they can move and get caught while closing everything up.
Amon Bouchereau - Responder
how do i know what persent my battery is at
jewon - Responder
Jewon today we have a hack for psvita 3.60 version ONLY !! this allow u download a VPK file that says how much persent your battery is at
brunosapo -
With your Vita connected to your PC and the Content manager application running, on windows right click on the vita and then properties and the battery percentage will show up.
Matthew Michand -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 88
Últimos 7 dias: 754
Últimos 30 dias: 3,587
Duração total: 244,821
