Introdução
This guide takes you through the process of installing the 3G antenna cable on the PlayStation Vita. This is the black antenna cable on the left of the wireless.
O que você precisa
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Using the pointy end of a spudger, gently pry the 3G antenna cable off of the wireless card.
Um comentário
I need mine fixed because it has came out but it isn’t a wire it is like a orange thin thing and it won’t clip back in
