Ir para o conteúdo principal
PlayStation Vita 3G Antenna Cable Replacement
O que você precisa
  1. PlayStation Vita 3G Antenna Cable Replacement, Case Separation: passo 1, imagem 1 %32 PlayStation Vita 3G Antenna Cable Replacement, Case Separation: passo 1, imagem 2 %32
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita 3G Antenna Cable Replacement: passo 2, imagem 1 %32 PlayStation Vita 3G Antenna Cable Replacement: passo 2, imagem 2 %32 PlayStation Vita 3G Antenna Cable Replacement: passo 2, imagem 3 %32
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita 3G Antenna Cable Replacement: passo 3, imagem 1 %32 PlayStation Vita 3G Antenna Cable Replacement: passo 3, imagem 2 %32
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita 3G Antenna Cable Replacement: passo 4, imagem 1 %32 PlayStation Vita 3G Antenna Cable Replacement: passo 4, imagem 2 %32 PlayStation Vita 3G Antenna Cable Replacement: passo 4, imagem 3 %32
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita 3G Antenna Cable Replacement: passo 5, imagem 1 %32 PlayStation Vita 3G Antenna Cable Replacement: passo 5, imagem 2 %32
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita 3G Antenna Cable Replacement: passo 6, imagem 1 %32
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita 3G Antenna Cable Replacement: passo 7, imagem 1 %32
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita 3G Antenna Cable Replacement: passo 8, imagem 1 %32
    • Separate the front and rear cases.
  9. PlayStation Vita 3G Antenna Cable Replacement, 3G Antenna Cable: passo 9, imagem 1 %32
    • Using the pointy end of a spudger, gently pry the 3G antenna cable off of the wireless card.
  10. PlayStation Vita 3G Antenna Cable Replacement: passo 10, imagem 1 %32
    • Using the pointy end of a spudger, gently pry the 3G antenna cable off the right button board.
    • Deroute the 3G antenna cable out of the casing and remove it.
Conclusão
Brittany McCrigler
Membro desde: 03/05/12
89.020 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.299 guias
Um comentário
I need mine fixed because it has came out but it isn’t a wire it is like a orange thin thing and it won’t clip back in
Jacob Gaming videos 123 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 39
Duração total: 7,750
