Ir para o conteúdo principal
PlayStation VR Processor Unit Thermal Pad / Fan Replacement
O que você precisa
  1. PlayStation VR Processor Unit Thermal Pad / Fan Replacement, Processor Unit Thermal Pad: passo 1, imagem 1 %32 PlayStation VR Processor Unit Thermal Pad / Fan Replacement, Processor Unit Thermal Pad: passo 1, imagem 2 %32
    • Place the PlayStation VR processor unit with the I/O (back) side facing up.
    • Peel the sticker up with a fingernail or a pry tool.
    • Remove the single J0 screw.
    • Place the screw in a parts tray to keep it organized.
  2. PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 2, imagem 1 %32 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 2, imagem 2 %32 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 2, imagem 3 %32
    • Use an opening tool to separate the bottom cover from the top.
  3. PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 3, imagem 1 %32 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 3, imagem 2 %32 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 3, imagem 3 %32
    • Remove the eight J0 screws.
    • Place the screws in the parts tray
    • Use your tweezers to disconnect the fan connector from the motherboard
    • If the fan needs to be replaced, stop here and follow in reverse.
    • Fan details.
    • Brand: Nidec
    • Model and dimensions: U35x05m 52aa7-56j14
    • Power: 5v and .18a
  4. PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 4, imagem 1 %32 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 4, imagem 2 %32 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 4, imagem 3 %32
    • Use a spudger or a fingernail to lift the pcb in the direction highlighted
    • Gently separate the metal plate from pcb
    • Replace the thermal paste if needed.
    • Use a fingernail or a pry tool to see if the thermal pad is still soft. that means it still conducts heat. if hard, remove and replace the thermal pad
Conclusão
Kalib Ellery
Membro desde: 10/17/16
477 Reputação
Autoria de 2 guias
Um comentário
Hi, is thermal pads being dry could be the reason for this processing unit not turning on? It lits the light for quick millisecond and goes out as i connect the barrel jack. :( I couldn't find any fix yet
Chandu Samarasekara - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 54
Duração total: 1,810
