Ir para o conteúdo principal
PlayStation VR Processor Unit Cooling Fan Replacement
O que você precisa
  1. PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: passo 1, imagem 1 %32 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: passo 1, imagem 2 %32 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: passo 1, imagem 3 %32
    • On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. PlayStation VR Processor Unit Cooling Fan Replacement: passo 2, imagem 1 %32 PlayStation VR Processor Unit Cooling Fan Replacement: passo 2, imagem 2 %32 PlayStation VR Processor Unit Cooling Fan Replacement: passo 2, imagem 3 %32
    • Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw.
    • Unscrew the 6mm screw with a PH #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. PlayStation VR Processor Unit Cooling Fan Replacement: passo 3, imagem 1 %32 PlayStation VR Processor Unit Cooling Fan Replacement: passo 3, imagem 2 %32
    • Slide the panel back into place.
    Pergunte ao FixBot
    Comentar
  4. PlayStation VR Processor Unit Cooling Fan Replacement: passo 4, imagem 1 %32 PlayStation VR Processor Unit Cooling Fan Replacement: passo 4, imagem 2 %32 PlayStation VR Processor Unit Cooling Fan Replacement: passo 4, imagem 3 %32
    • Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports.
    • You will probably need to lift it on both sides in order for the panel to come loose.
    Pergunte ao FixBot
    Comentar
  5. PlayStation VR Processor Unit Cooling Fan Replacement: passo 5, imagem 1 %32
    • Turn the console over.
    • Unscrew the two 9 mm screws with a PH #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. PlayStation VR Processor Unit Cooling Fan Replacement: passo 6, imagem 1 %32 PlayStation VR Processor Unit Cooling Fan Replacement: passo 6, imagem 2 %32
    • With the plastic opening tool, carefully pry the console shell panel free and lift it away.
    Pergunte ao FixBot
    Comentar
  7. PlayStation VR Processor Unit Cooling Fan Replacement: passo 7, imagem 1 %32 PlayStation VR Processor Unit Cooling Fan Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console.
    • Carefully lift the fan and its wiring from the device.
    • Be mindful of damaging the wires.
    • Take care to keep your fingers away from the fan blades.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Sarah Shand
Membro desde: 02/20/17
1.996 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team S3-G1, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G1
3 Membros
Autoria de 14 guias
4Comentários do guia
Where do I get a replacement fan tho?
Ponos King - Responder Compartilhar
I think is a 3x3 cm fan, alliexpres has some, but what voltage?
crus - Responder Compartilhar
5V is what i have read
Ethan Amos - Responder Compartilhar
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
herossuperman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 22
Últimos 30 dias: 91
Ao todo: 10,682
