Ir para o conteúdo principal
PlayStation VR Band Adjuster Replacement
O que você precisa
  1. PlayStation VR Band Adjuster Replacement, Band Adjuster: passo 1, imagem 1 %32 PlayStation VR Band Adjuster Replacement, Band Adjuster: passo 1, imagem 2 %32 PlayStation VR Band Adjuster Replacement, Band Adjuster: passo 1, imagem 3 %32
    • Use your hands to remove the foam piece in the headband.
    • Use the iFixIt Opening Tool to pry the top and bottom trim pieces off of the rear band assembly.
  2. PlayStation VR Band Adjuster Replacement: passo 2, imagem 1 %32
    • Remove a total of four 5 mm screws from inside the left and right sides of the headband using a Phillips #00 screwdriver.
  3. PlayStation VR Band Adjuster Replacement: passo 3, imagem 1 %32 PlayStation VR Band Adjuster Replacement: passo 3, imagem 2 %32
    • Remove three silver 5 mm screws that are securing the rear white cover of the band using a Phillips #00 screwdriver.
  4. PlayStation VR Band Adjuster Replacement: passo 4, imagem 1 %32 PlayStation VR Band Adjuster Replacement: passo 4, imagem 2 %32 PlayStation VR Band Adjuster Replacement: passo 4, imagem 3 %32
    • Remove the 6 mm screw from the retainer securing wires to the rear band assembly using a Phillips #00 screwdriver.
    • Use a spudger to flip up the retaining flap connected to the rear LEDs.
  5. PlayStation VR Band Adjuster Replacement: passo 5, imagem 1 %32
    • Remove the single 5 mm screw from the center of the headband adjuster using a Phillips #00 screwdriver.
  6. PlayStation VR Band Adjuster Replacement: passo 6, imagem 1 %32
    • Gently pry the adjuster assembly away from the rear headband using an opening tool.
  7. PlayStation VR Band Adjuster Replacement: passo 7, imagem 1 %32 PlayStation VR Band Adjuster Replacement: passo 7, imagem 2 %32 PlayStation VR Band Adjuster Replacement: passo 7, imagem 3 %32
    • Disassemble the adjuster assembly spring, small gear, large gear, and bracket in order to replace the broken component.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 18
Últimos 30 dias: 64
Duração total: 2,422
