Ir para o conteúdo principal
PlayStation TV Thermal Pad Replacement
O que você precisa
  1. PlayStation TV Thermal Pad Replacement, Motherboard: passo 1, imagem 1 %32 PlayStation TV Thermal Pad Replacement, Motherboard: passo 1, imagem 2 %32
    • Use the plastic spudger to pry up the bottom piece of the case to release the clips.
  2. PlayStation TV Thermal Pad Replacement: passo 2, imagem 1 %32 PlayStation TV Thermal Pad Replacement: passo 2, imagem 2 %32
    • Remove the four 6 mm Phillips screws.
    • Remove the two Phillips #0 screws.
  3. PlayStation TV Thermal Pad Replacement: passo 3, imagem 1 %32 PlayStation TV Thermal Pad Replacement: passo 3, imagem 2 %32
    • Remove the heat shield using the plastic opening tool.
    • Slide the tool around the edges until the shield is free.
  4. PlayStation TV Thermal Pad Replacement: passo 4, imagem 1 %32 PlayStation TV Thermal Pad Replacement: passo 4, imagem 2 %32
    • Remove the last 6mm Phillips #0 screw from the motherboard.
  5. PlayStation TV Thermal Pad Replacement: passo 5, imagem 1 %32 PlayStation TV Thermal Pad Replacement: passo 5, imagem 2 %32
    • Use a plastic opening tool to pry up gently on the motherboard, and remove it.
  6. PlayStation TV Thermal Pad Replacement, Thermal Pad: passo 6, imagem 1 %32 PlayStation TV Thermal Pad Replacement, Thermal Pad: passo 6, imagem 2 %32
    • Remove the old thermal pad with an ESD safe tool, like a Jimmy.
  7. PlayStation TV Thermal Pad Replacement: passo 7, imagem 1 %32 PlayStation TV Thermal Pad Replacement: passo 7, imagem 2 %32
    • Wipe down the area where the old thermal pads were located with rubbing alcohol.
    • It is important that the area be as clean as possible.
Conclusão
3 outras pessoas executaram este guia.
Theodore Hesse
Membro desde: 01/22/16
145 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 3-1, Baechle Spring 2016 Membro de IUPUI, Team 3-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G1
Membros da 4
Autoria de 4 guias
2 comentários
Photos for steps 6 through 9 will be posted soon!
Luk Davis - Responder
Do you replace the thermal pad? Your directions do not state where to do this, and if so what part and size do you recommend?
Daimonion - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 30
Duração total: 1,847
