Introdução
However, the Sony engineers also included a thermal pad to aide heat transfer in their design. These thermal pads can be worn out with excessive use, or severe overheating events. After this, it is best to replace the pads to keep the device performing optimally.
O que você precisa
Use the plastic spudger to pry up the bottom piece of the case to release the clips.
3 outras pessoas executaram este guia.
