Ir para o conteúdo principal
PlayStation One Mother Board Replacement
O que você precisa
  1. PlayStation One Mother Board Replacement, Upper Case: passo 1, imagem 1 %32
    • Remove all cables plugged into the PlayStation.
  2. PlayStation One Mother Board Replacement: passo 2, imagem 1 %32 PlayStation One Mother Board Replacement: passo 2, imagem 2 %32
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. PlayStation One Mother Board Replacement: passo 3, imagem 1 %32
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. PlayStation One Mother Board Replacement: passo 4, imagem 1 %32 PlayStation One Mother Board Replacement: passo 4, imagem 2 %32
    • Lift up and remove the upper case.
  5. PlayStation One Mother Board Replacement, Laser Assembly: passo 5, imagem 1 %32 PlayStation One Mother Board Replacement, Laser Assembly: passo 5, imagem 2 %32 PlayStation One Mother Board Replacement, Laser Assembly: passo 5, imagem 3 %32
    • Disconnect the cables from the PSone’s board.
    • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
  6. PlayStation One Mother Board Replacement, Mother Board: passo 6, imagem 1 %32 PlayStation One Mother Board Replacement, Mother Board: passo 6, imagem 2 %32
    • remove the metal plate
    well well a modded ps one hahah
    Bernabe Alvarez - Responder
  7. PlayStation One Mother Board Replacement: passo 7, imagem 1 %32 PlayStation One Mother Board Replacement: passo 7, imagem 2 %32 PlayStation One Mother Board Replacement: passo 7, imagem 3 %32
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
Conclusão
14 outras pessoas executaram este guia.
Marjorie
Membro desde: 12/23/13
2.273 Reputação
Autoria de 11 guias
Um comentário
I think that the GPU in my PS One is going bad (screen flickers green and pink on occasion but it is becoming more frequent). Would replacing the motherboard fix this? That is, is the GPU stored on the motherboard?
Eric Rosenberg - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 143
Duração total: 11,298
