Ir para o conteúdo principal
PlayStation Move Motherboard Replacement
O que você precisa
  1. PlayStation Move Motherboard Replacement, Battery: passo 1, imagem 1 %32 PlayStation Move Motherboard Replacement, Battery: passo 1, imagem 2 %32 PlayStation Move Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
  2. PlayStation Move Motherboard Replacement: passo 2, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 2, imagem 2 %32
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
  3. PlayStation Move Motherboard Replacement: passo 3, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 3, imagem 2 %32
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
  4. PlayStation Move Motherboard Replacement: passo 4, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 4, imagem 2 %32 PlayStation Move Motherboard Replacement: passo 4, imagem 3 %32
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  5. PlayStation Move Motherboard Replacement: passo 5, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 5, imagem 2 %32
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
  6. PlayStation Move Motherboard Replacement: passo 6, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
  7. PlayStation Move Motherboard Replacement: passo 7, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 7, imagem 2 %32 PlayStation Move Motherboard Replacement: passo 7, imagem 3 %32
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
  8. PlayStation Move Motherboard Replacement: passo 8, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 8, imagem 2 %32
    • Gently pull on the white piece connecting the battery and the connector.
  9. PlayStation Move Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 PlayStation Move Motherboard Replacement, Motherboard: passo 9, imagem 2 %32 PlayStation Move Motherboard Replacement, Motherboard: passo 9, imagem 3 %32
    • Remove the five 1.2 mm screws from upper portion of the controller.
    • If you are replacing the trigger button, continue to step 13.
  10. PlayStation Move Motherboard Replacement: passo 10, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 10, imagem 2 %32
    • Remove the two 1.2mm Phillips #1 screws.
  11. PlayStation Move Motherboard Replacement: passo 11, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 11, imagem 2 %32 PlayStation Move Motherboard Replacement: passo 11, imagem 3 %32
    • Cautiously remove the circular white piece at the top without removing the LED inside.
  12. PlayStation Move Motherboard Replacement: passo 12, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 12, imagem 2 %32 PlayStation Move Motherboard Replacement: passo 12, imagem 3 %32
    • Remove the blue strip that is connected to the trigger button from the motherboard.
    • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
  13. PlayStation Move Motherboard Replacement: passo 13, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 13, imagem 2 %32
    • Remove the trigger button from the controller.
  14. PlayStation Move Motherboard Replacement: passo 14, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 14, imagem 2 %32 PlayStation Move Motherboard Replacement: passo 14, imagem 3 %32
    • Remove the LED light by removing the white strip.
    • If you are replacing the LED light, continue to Step 17.
  15. PlayStation Move Motherboard Replacement: passo 15, imagem 1 %32 PlayStation Move Motherboard Replacement: passo 15, imagem 2 %32
    • Remove the motherboard from the plastic case.
Conclusão
Uma outra pessoa concluiu este guia.
Destiny Jenkins
Membro desde: 09/28/16
157 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 3-3, Passmore Fall 2016 Membro de USF Tampa, Team 3-3, Passmore Fall 2016
USFT-PASSMORE-F16S3G3
Membros da 4
Autoria de 8 guias
2 comentários
Where does one obtain a replacement motherboard?
Tekkromancer - Responder
my controllers are also dying anyone know where to get a replacement board? I live in Canada
Jin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 1,610
