Introdução
Use this guide to replace the LED light on the Playstation Move
O que você precisa
Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
3 comentários
Okay, going to try this. Do I have to solder the white strip back onto the board?
did you ever get this done? need to know the same.
