Introdução
The battery is an integral part of the PlayStation Move controller. This guide will help you to remove and replace it with ease.
O que você precisa
Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
Using tweezers, carefully pull the power cable from its port on the circuit board.
8 outras pessoas executaram este guia.
